RCU Forums - View Single Post - Hangar 9 - Extra 260 - Electric Conversion
Old 06-09-2005 | 08:10 PM
red_z06's Avatar
red_z06
Default RE: Hangar 9 - Extra 260 - Electric Conversion
Don't waste your money on Pyramid Garbage power supply. It was rated for 40amps with 35amps continuous. When 18amps are loaded, it cuts out in less than 30min. When I called them, they said the duty cycle is 15min full, 45min idle. What bull**** @#$@#$.
So, it is good enough for 1 astro charger. You are better off getting Radio Shack 25amp switching power supply.
Drumbum:
You only need one Astro charger. I'm using 3 cause I want to fly it non stop. BTW, the Vette is actuall $53,000. It is a Z06 (405HP) not a regular vette.
