RCU Forums - View Single Post - Compression Testing a 50cc engine ?
Old 06-10-2005 | 08:22 AM
pe reivers
Default RE: Compression Testing a 50cc engine ?
In that case, Yes, you can use a compression gauge to test the condition of your engine, though I do not know anyone who does it on two stroke engines.
You can take your plane to a garage and have them test compression.
The engine must make several revolutions, so you will also need an electrical starter that is up to the job at hand.
