RE: Venus Construction Questions
I ran my saito 72 upside down with no issues. the trick is to lean out the low end needle but not to much. once set, it never needs to be touched.
no need to fiberglass as long as you do a good job joining the wing
I used the stock elevator methods with 1 Hitec 475 servo. I also soldered the 2 push rod wires together.
