RCU Forums - View Single Post - Digital Servos on KingCat flaps?
Old 06-10-2005 | 04:02 PM
S_Ellzey's Avatar
S_Ellzey
Default RE: Digital Servos on KingCat flaps?
This all comes down to how the servos are controlled. A conventional servo applies power to the motor that is propotional to the error in its position. For example; you commmand the servo to move 12 degrees, the air load is trying to stop this, in the end the servo moves less than 12 degrees. It might take a degree or two of error for the servo to generate enough power to hold against the air load. A digital servo on the other hand will command it self to near full power to get to the commanded position. This is why digitals are better, they go where you tell them to go, analogs only get close, they must by design travel short of the command when under load.
This is easy to see. Power up an analog servo and try to move the arm, try hard. The output arm will move a ways before it really fights back. Then try it with a digital, you can not move it. It is the nature of the two beasts.
Steven
ORIGINAL: FLYBOY2000
But wouldn't a digital or NON digital do the same thing.. TRY to get the surface to the commanded position until it is told otherwise. I can see that the digitals are more power consuming. I always thought the main reason was due to the air load on the surface, especially KC "barn door" flaps...Hopefully Doug C. will chiime in.
Thanks fellas
S. A. Leo
