Antenna routing?
I'm trying to finish up an Ultra RC YAK and I'm to the antenna routing stage. I was going to try a Deans whip, but just dont have the courage to cut the receiver antenna.
I have run a tube from the back of the fuse, but am worried about the antenna running parallel to the pull-pull rudder wire. The tube runs under, then crosses, then runs above the pull-pull. It does not come in contact anywhere along the run. Is this OK or should I find another way to route the antenna?
Looking at the run it looks like the closest they get to each other is about 3/4".
