RCU Forums - View Single Post - Converting Avistar to nylon wing bolts: How to
Old 06-11-2005 | 07:14 AM
bruce88123
Default RE: Converting Avistar to nylon wing bolts: How to
Any place where you are going to be tightening down a bolt on the wing, it should be reinforced so the wing won't crush. Often this can just be a small plywood plate on outside to distribute the load but sometimes you must fill the inside area too. Depends on wing structure.
