RE: Antenna routing?
if you have already ran the tube, i would say set it up
then go thorugh your range check
also check with the eng running too
is the tube plastic? or waxed cardboard?
chances are the anntana will be insulated
running through the fuse is a clean set up
any chance of exiting out the anntana just behind the t/e
if you are geting glitches?
let us know of your findings...
