I think a stadium truck looks great with practically any kind of body on it. I went with a XXX-NT body and painted it just a plain Pactra Metallic Blue. Most ST body's have so many curves and bulges, that they look great with simple paint jobs.
XXX-NT body's will fit the stock mounts, but may need a little tweaking in other areas. I had to cut out a part of the rear deck on the side for the head to poke through slightly, but I had a different engine than stock. The header rubs the body a little closer than it should, so it rubs the paint off. Other than that, it's no big deal. It's the same kind of thing you would do with any body. It's just lexan, not like you have to hack through some steel or something.
Other style body's will require the use of your imagination and that you utilize other body-mounts.
