RCU Forums - View Single Post - Antenna routing?
Old 06-11-2005 | 04:24 PM
rflasch
My Feedback: (8)
Default RE: Antenna routing?
So much depends on the equipment you are using....Good rule of thumb...if you can run your antenna outside the fuse DO IT. Try to avoid crossing servo lead wires (and extensions)....definitely isolate your power lead from all servo leads to avoid any chance of crossover...jmho do as you like!!
