RCU Forums - View Single Post - Antenna routing?
Old 06-11-2005 | 09:28 PM
Salty25's Avatar
Salty25
My Feedback: (9)
Default RE: Antenna routing?
I understood your situation, thought I'd offer a suggestion on how I route mine.
Does your pull-pull criss cross or run down both sides? Most run them straight down the sides but there are people that have them cross in the fuse; it's suppose to be easier on the servo or something.
If you do cut the antenna on the rcx and don't like it you can always solder a new on. It's not hard, unless you don't know how to solder; but maybe you can get someone to do it for you.
However, if it was my plane.... I'd go with the wire under the fuse. You can see how I did it on my 4*60 that had pull-pull. Small piece of fuel tubing in the hole to prevent chaffing, a clip on the inside for stress relief and one at the far end to hold tension. I've done this on a lot of my planes.
This is just a suggestion of another possibility. I don't know if you will have probs with running the wire inside with the cables for your pull-pull.
Good luck.
