If your going to do a lot of nose up, hovering etc. set the carb mix with the nose pointing up and put the tank as close to the firewall as possible. If it has the large round plug on the front of the tank, bore a hole in the firewall large enough to stick it through. makes it easier to hook up the fuel lines too.
