RCU Forums - View Single Post - 46fx Pumped???
Old 06-12-2005 | 07:12 AM
Flypaper 2
Default RE: 46fx Pumped???
Using a pump allows you to put a larger carb on the engine for more power where it makes up for lower fuel draw. Check out the carb throat size on the pumped OS 61 compared to the unpumped version and the difference in power. There's nothing the matter with the 46 FX. The peeling problem is old history.
