RCU Forums - View Single Post - Official Nitro Evader ST Thread
Old 06-12-2005 | 03:26 PM
  #2798
thestratcat's Avatar
thestratcat
My Feedback: (12)
Default RE: Official Nitro Evader ST Thread
ORIGINAL: delasueno
I just bought some rpm clawz for the losi xxx-nt because they are supposed to fit the evader. I have no problems with the rear rims but when I installed the front rims and tightened down the wheel nut my tire wouldn't budge at all. I thought the rim might be rubbing on the steering arm but it wasn't touching it. I took off the front and put the old duratrax wheels back on, tightened them all the way and they would spin fine. Why won't the *&&% losi rims spin when I tighten down the nut? Any suggestions from anyone?
make sure you use that inner spacer that goes between the bearings, this will put them just a hair thicker than the hub, so when you tighten them down they will spin. Without the inner spacer, it won't work.
