RCU Forums - View Single Post - Questions.........
Old 06-13-2005 | 12:08 AM
piperofna
Default Questions.........
Hi..
Q1
My piper 3 uses the engine range btwn .20 to .28 stroke engine..can i have a .35 FLASH engine mount on it and yet not cause any imbalance or sort??
Q2
One more thng the engine mount is a two piece balsa wood wedge into the firewall..but the supporting balsa seems to offset to the right of the plane(assuming im facing the plane front)...is this suppose to be normal cause when the engine is mounted, the engine seems to tilt to the right a little.
Q3
To start the engine running shld i get a 12V startter or jus manually using a dowel....??
