RE: Impact
Hi All, Below is a note I passed to the NSRCA discussion list regarding flying this weekend.
I flew the Impact 4 flights this weekend. I did this while flying my Aggressor, and breaking in a new OS 140 RX. It was one of the funnest, BEST pattern day's I've ever had. I flew the E-Impact and immediately liked the power and speed control (and ease). The Impact itself, didn't jump off the board as a perfectly trimmed plane, so I knew I had a little work to do. After the first flight, the concept was DEFINITELY proven, and I quickly deduced that I need more batteries (first flight was Saturday evening). After this first flight (with John B. from Surinam watching), we determined the need to paint the bottom of the wings and canopy. We ran to Lowes and bought some florescent red/orange to paint the stab and wing tips, and we also painted the canopy metallic silver. Also determined that the plane was tail heavy quite a bit. Anyone familiar with the Impact thread on RCU knows exactly what I'm talking about in regards to the Impact.
Sunday morning with CG moved forward, the plane flew better and the small amount of color we put on the plane definitely made a huge difference. After this second flight, also determined that the CG was still too far aft, and that the battery needed to be moved forward (at this point, knife edge needed no mixing), and the plane was carrying a small amount of aileron trim.
Then, I flew the Aggressor for the first flight with the OS 140 RX and 17x10 APC. With th 17x10, the OS was nearly "super-sonic" compared to the Impact, however immediately, the Aggressor's trimmed status and "locked-on" look/feel was evident (as anyone who has seen the plane fly in D3 would attest to. Due to charging time of the E-Impact, I swapped props to the Mez 18x10, adjusted the throttle curve, and started moving the speed envelope of the Aggressor down to match the Impact in a couple more flights. My first thought was that if I had the E-setup in the Aggressor, it would be an unstoppable machine! (Aggressor weight without fuel is 10 lbs 13 oz).
Time for another flight on the Impact. I flew through PO5 this time, and started getting used to the E-power curve, some rates, etc. The forward CG move started to pay off, and the plane was drawing better lines (but still not like my glow plane, which is understandable as this was only the third flight on the model). After this flight, again, decided the CG needed to go MORE forward. Also, we determined that the right wing tip needed about 14 grams of weight to laterally balance the model (a step I did not do in the garage, we added the tip weight at the field).
Back to the Aggressor: I flew two more flight back to back on the Aggressor, each time improving the throttle curve to make it easier to match the envelop of the Impact. The OS ran perfect, and I'm sad that after 5 years of screwing with other engines, to have not just spent the little bit of extra money and ran the OS all along. Through each flight (90 degrees, 90% humidity), the OS ran superb. Inflight throttling was great, you could tell the motor was not getting hot, and it was making ridiculous vertical power. (by the way, this was on an OS A5 plug, C.P. 25% pro-pattern, and ES pipe). The OS runs VERY smooth with a crazy low idle. I'm VERY happy with how it ran - not a single dead stick through its first 5 flights - nothing but awesome performance. The locked in (trimmed) status of the Aggressor, now flying in the slower speed enveloped, had convinced John that this was still the "ticket" as compared to where the Impact was after 3 flights.
Back to the E-Impact!!!!!!!!!! For this flight, the 6000 Pro-Lite T.P. battery was moved as far forward as possible (just behind motor). This flight showed some incredible potential. In this CG config., the Impact was driving lines similar to the Aggressor (up, down, 45's, etc), and rolling VERY well. Also, the wing tip weight on the right wing made EVERY SINGLE MANEUVER look better. The wings were much more locked on, the plane rolled better, exited snaps better, spinned better. This was a great trimming lesson to me, as the day was getting cross-windy (worse) through out the day as the ruminants of the tropical storm passed through, however in the worsening conditions, this was the BEST of the flights.. After this flight, John immediately was convinced that this was indeed going to be a solid backup or first plane for the nats. I'm still going to move the receiver battery forward now though, and probably make a lighter rudder (which wouldn't hurt things anyway). (hacker controller has 3 degrees timing).
Charging: I alternated by charging from the car battery, then letting the car idle for the next charge (guess what - no big deal to do this if necessary). However my limitation is that I only have one Astro 109 as the second one has not arrived yet. Thus, instead of 45 minute turnaround times, I was 1.5 hrs between flights.
Impact: I followed some RCU advice and started with a CG on the center of the wing tube, without wings on. This is in serious error. However, the plane will dive mildly when in inverted flight, and it gives the impression through simple tests that the CG is correct. With this CG, the plane flys off the tail. In radius, the tails squats and the plane will fly tail low. After I was done with it, the plane was following the nose, driving excellent lines, similar to the Aggressor (still thanking Tony F. for the trimming help on my Lazulite,which has now gone into all my planes!).
Glow / Electric: In a quick comparison, a trimmed plane is what you need. Electric power itself will help with presentation and probably hide some airplane tendencies (if bad), due to the smaller speed envelope. Although, the power and the plane are working together, they are still a bit separate. I guess I'm trying to say that a poorly trimmed plane is going to hurt you no matter what motor you have in it. I'm guessing purely guessing now though, that if two identical planes, both completely trimmed, were equipped with glow and electric, that the E-setup would take the cake as it would allow more of a "show-casing" of the maneuver set. More to follow.........
Thanks, welcome questions, comments, public or private
IMPACT: I'm carrying a slight aileron trim, and will need to "pin" the front of the wings once I decide if the trim is worth adjusting out or not.
Jim W.
