RCU Forums - View Single Post - Composite ARF Impact
Old 06-13-2005 | 04:13 PM
  #632
byoung466
My Feedback: (16)
Default RE: Impact
My CG is at 178 mm from the LE of wing. LE of wing to LE of tube is 150mm.
Im also using 2 degree down thrust, anyone else using down thrust?
The Plane is flying straight up, needs some down pressure on downlines, needs slight down pressure inverted. Knife has no tuck or pull. Very heavy rudder does roll and tuck the nose.
