RCU Forums - View Single Post - just got a CEN Genisis
Old 06-14-2005 | 09:01 AM
benifur's Avatar
benifur
Default RE: just got a CEN Genisis
well I drove it around yesterday, I moved the streering out 2 holes on the sevo horn and tightend the sevo saver it was way loose, and it turns alot better, before I started I thought I'd check the gear mesh and found the cluch bell was falling off (we're talking brand new out of the box truck hear is falling apart), any way with that fixed is out back to the track well I went pretty slow the frist tank it never seen 2nd gear, the 2nd tank thought I'd going alittle faster well I was wrong when it goes to shiff it has a hard time if you get on the gas it'll shift but it jumps to the right when it goes into 2nd and it shakes going in and coming out so I shut it down and gave up. today I set the gear cluches and see if that helps.
AB I put a motor saver air filter on all my RC's I just didn't like the way the stock one is, looks to me like it could get dirt in the carb past it so I never even used it I could be wrong but it just dosen't look rite to me
