RE: Biplane rolls violently left on takeoff
Most probably a warped wing, this should be quite evident if you look at the plane from the aft end and see if both left and right wing panels give you the same view. Also, make sure you have about 3 degrees of right thrust and probably about 3 degrees of down thrust.
