RE: Machinist guru help needed
I was using lube, but obviously going to slow with too much pressure. My setup is a drill-press with a vice on a cross-slide, so it is reasonably rigid.
I suppose I could also use my mill, and then I could control the feed rate better.
Thanks for the advice!
