RE: engine on RAZZLE
I did not renforce the tail with wires I felt I would not put the tail to the test as my
flying ablities are not really that great and I do not put that much stress on the airplane.
Here are some pictures of the aiplane with the carbon fiber rods I put on the elevator and
aileron servos. I should have done it to the Rudder too as I feel that is part of the problem.
Vibration from the loose servo arm vibrated the tail which vibrated the pins out of the tail
structure. I would replace the pins with toothpicks and CA or at least CA the pins to the
wood. I do not believe that they are CA'ed in place and when I removed the hinges from the
tail structure it only took a pair of needle nose pliers and very little pulling to get them out of the airplane.
John
