RE: ThunderTiger Rare Bear
Rich
I do not agree that Rare Bear is a good buy. I had one and the stabs blew out on the second flight at part throttle, using a ys91 with a 14x10 prop. I purchased a CMP F6F Hellcat for $200 and found that model to be a better product for less money. The bulkheads were glued in with sufficient glue and all I did was add glue to the retract mounts with a hypodermic needle. It has taken some rough landings without damaging the structure. It also has a fiberglass fuse. Ace is way behind and they refuse to acknowledge it.
Dan
