RE: new os cvr .18
Thanks again for the reply back guys. I understand what poor judgement is saying. If you have the standard 2 speed pinion gears like me, then your clutch bell will be the 11tooth / 14tooth pinions. Your nylon spur gears will be 44T and 47T respectively. He was saying originally that the 11tooth pinion will line up properly with one of the Genesis metal spur gears but we need the 15tooth other clutch bell gear, so that the other genesis spur gear will work properly. I forget which gears are considered 1st and 2nd gears, but you get what im saying. Now that I have the part numbers needed from Poor Judgement, I will be ordering a set. So if ya want CenRacer, give me a week or so and I will definitely let you know how it works out. After reading his latest reply, now I understand what he was saying in the previous responses. As I told you guys, it does take me a few rounds to get it. I will order the parts tonight. Thanks Poor Judgement. You came through with the answer again. You CenRacer seem to be providing me with most of my CEN answers. Where are you guys located? Im in Los Angeles, California. Just curious. THanks Again. [sm=cool.gif]
