RE: Trainer Trash resurection
here are some of the repair pictures so far , you can see that i have cut new front peices for the fus , these are epoxied in place and supported with 1/64 ply doubles and also the upper and lower peices i have fitted are ply to add extra strength to this joint , you can see where i have re created the servo tray , this was one from another wreck that i cut to size , also you can see the new vertical stab assembly i have created , some of the repairs to the wing , i still need to replace six ribs , and my simple adjustable engine mount design , incase i have the posistion of the front bulkhead slightly wrong
this is 2 days of work . more to follow
as to the qeustion of rebuilding , well .i built my last 2 planes from scratch using only plans i downloaded , and depending how bad it is , it seemed quicker to rebuild this than start from nothing
Rick
