RE: Can I get a WITNESS???
Right now the F-14 stats are.
Starting from the nose...................
Functional:
Camera pod with GPS
Air to Air refueling probe
Canopy with cockpit gauge lights
Ejection seats with scale parachutes
Navigation, Landing and strobe lights
Inlet ramps
Slats,Spoilers, Flaps
Wing Sweep
Droptanks (they hold 16oz fuel each.)
"Tarps Pod" (for in-flight high res still shots.)
Speed Brakes
Tailerons
Rudders
Tailhook
Gear/Wheel Brakes
Afterburner Light Rings
The jet weighs 34 lbs full of fuel with all hardpoints mounted.
Carrying 1 Gallon of Jet A
Two Artes Superbees at 14 1/2 lbs of thrust each blowing through two "thrust tubes" from Goldenwest giving approximately 1 1/2 lbs more thrust each side and out two stainless steel cones from Tam.
