RE: Edge 540T problems proving unresolvable
Incidences would be the first thing I would check. Next, run the trimming sequence by Peter Goldsmith in the Model Aviation Feb and Apr mags. Even if the wings are the same weight you still might have some balancing to do when the wings are under an aerodynamic load. All your mixing troubles could be caused by the combination of these two things (incidence and trimming).
Good luck! Let us know what happens!
