RCU Forums - View Single Post - Stock F27 Stryker Help Line
Old 06-15-2005 | 01:57 PM
Jetpilot/Ghostrider's Avatar
Jetpilot/Ghostrider
Default RE: Stock F27 Stryker Help Line
Hi all,
I need to make some foam repairs but need some product info and repair advice. I have some chunks of foam missing from the leading edges of my wing. Hitting trees, fences etc. I would like to know if there is any kind of light foam filler that I can use. I was thinking about cutting out the wrecked area and glueing in a fresh piece of foam, sanding to contour and repainting the area? I was also thinking about the foam spray that you can buy at your local hardware store that you spray into cracks and it expands and hardens, sanding to contour and repainting the area. First of all I don't know what the weight of the material would be once hardened and what the effects it will have on foam? Any suggestions would be nice. I'm a show and go flyer so my birds gotta look FRESH and SWEEET!
Thx,
JPGR
