RE: I have a Hyper .21 w/o pullstart
He means you DO NOT WANT TO CONVERT TO PULLSTART. They cause these engines to lose their tune due to the air leaks they allow.
You WOULD NOT need a new crank if you did go ahead with it though.
The .26 lump will fit if you cut a slot in the lower mount plate. Almost all engines will fit the Hyper 7 if the are designed for 1/8th scale.
