RCU Forums - View Single Post - question on balancing an aircraft
Old 10-17-2002 | 02:11 PM
jettstarblue's Avatar
jettstarblue
Default question on balancing an aircraft
Just a thought, when setting up aerobatic planes, a enough weight to the left wingtip so that the plane is SLIGHTLY heavy on the left wing. This will help in your vertical lines. It also helps with high winghers, though not as much.-Try it.
Jetts
