RE: Sticky/Stiff BME Throttle Arm
I was referring to the one on the throttle shaft inside of the carb. You might have hit and bent the shaft which can cause it to seem sticky.
Is there any binding in the linkage that could be causing this? If not tear the carb apart and see what the problem is.
Oh and by the way adjust those needles or find someone to help you do that. Factory settings are just a ball park adjustment, NOT perfect for all environments.
