RCU Forums - View Single Post - Composite ARF Impact
Old 06-16-2005 | 03:19 PM
  #643
JRW
Default RE: Impact
Hi All,
After lots of vertical lines, and inside loops, I have set the rudder trim and the result is not good. The lower tip of the rudder counterbalance is 3/16" offcenter to the vertical fin, in a Left rudder direction. I've gone through this rudder trim trial for several flights, not believeing my eyes that this was necessary, but it is. When pushing from inverted flight to an upline, a lot of right rudder is needed to hold the line through the radius. I do believe I can see some Right rudder direction molded into the vertical fin.
Has anyone else done loop tracking, and needed a bunch of left rudder? Possibly an effect of the E-22x12???
Jim W.
