RE: Hardwire Servo Reverse Possible?
Reversing a servo by rewiring requires you to swap the two leads on the motor with each other, and then swap the two outside leads on the feedback pot with each other. Because many servos have the motor and feedback pot soldered directly to the circuit board, this becomes problematic. The only solution is to use a reversing "Y" harness or MSA-10 Servo Synchronizer.
