RCU Forums - View Single Post - Composite ARF Impact
Old 06-16-2005 | 10:29 PM
  #645
Eric.Henderson's Avatar
Eric.Henderson
Default RE: Composite ARF Impact
ORIGINAL: awat65
To those who have put a OS 160 engine on their Impacts, did you mount your elevator servos in the tail of the plane? and if you did, did you mount the servos in the elevator stabs or on the side of the fuse?
With both of mine the rudder and elevator servos are at the back of the canopy area. The Li-ion is on the landing gear. Goes up and down hands off with a bit of throttle mix.
Jim,
The fin needed to be held straight and squeezed with a "former" when fitting the stab tubes and the stern post. Sorry if this is late info.
Eric.
