RCU Forums - View Single Post - Aerofly model to reflex conversion??
Old 06-17-2005 | 05:21 AM
Lego_DK
Default RE: Aerofly model to reflex conversion??
Hi,
'conversion' is impossible due to the completely different simulation-engine the sims use.
AFP(D) simulates based on geometry, Reflex simulates based on parameters. This is 100% incompatible.
There is a way when you have the original 3D-model to import it into the RMK so you save the modelling work, but due to Reflex' limited polygon number in most cases this will also fail.
So theoretically you can have an AFP(D) model of poor quality in Reflex, but this way is so long and difficult that it is easier to build the model in RMK from scratch.
The flight parameters have to be programmed from scratch anyway...
Greets,
Lego
