RE: TF GS P47 Build - yeah another bloody one!!
Latest progress:
RHS wing
Finished modifying the retract mounts so I can actually get them back out now!
Added about 1 degree more of down angle on the mounts.
sanded all ribs even
Airlines run
Servo leads run, these will be terminated with connectors and joined as Y later on.
Wheel wells fitted out with walls, will glass the bottom & walls of the wells in next day or so. then I will sand the walls down to the same level the sheeting will be. Once that is done and the glassing is completed in the wells I will add some plastic L strut upside down to run lengthwise as per full size.
Then a coat of Zinc chromate before sheeting is done.
a few pics included
cheers
Peter
