PCM or FM RX on an electronic iginition engine?
I was once told that I had to only use a PCM receiver when using an electronic ignition on a gas engine. Is this true or can I use an FM receiver? To this point I have only run magneto ignitioned engines and have had no problem using FM receivers. I was told an electronic ignition interferes with the receiver. Any advice would be appreciated. Thanks!
