RCU Forums - View Single Post - confuse over fuel formula
Old 06-18-2005 | 08:01 PM
papermache
My Feedback: (35)
Default RE: confuse over fuel formula
one thing I left out. If you're getting a LOT of sludge, try using a bit less castor. Maybe a 4.5 or 5 to 1 mix. Also if you can find a source for some synthetic lube it might make things a lot better. Whatever you do, do all your testing on the same engine. If you burn up one engine it's a lot less expense than if you do the same to several.
papermache
