http://www2.towerhobbies.com/cgi-bin...?&I=LXBGB0&P=0
SPECS: Wingspan: 52" (1320mm)
Wing Area: 725 sq in
Weight: 3.5 lb
Wing Chord: 14" (355.6mm)
Airfoil: Semi-Symmetrical High-Wing
Center of Gravity: 4.52" (115mm) Back from the wing's leading edge
before engine is mounted. ( See manufacturer instructions)
Control Throws- Low Rate High Rate
Ailerons: Up & Down 1" (25mm) 1.40" (35mm)
Elevator: Up & Down 1" (25mm) 1.40" (35mm)
Rudder: Right & Left 3.14 (80mm) 4.33" (110mm)
