RCU Forums - View Single Post - PCM or FM RX on an electronic iginition engine?
Old 06-19-2005 | 08:09 AM
chuck l
My Feedback: (17)
Default RE: PCM or FM RX on an electronic iginition engine?
Good, thread, but I have a sporatic glitching problem on my OMP 65" Yak that I could use some help with.
The plane range checks just fine on the ground with and without the engine running, only thing is we have to lift it a foot or two off the ground. The antenna runs out the bottom the the plane, so it is very close to the grass. We range checked it again on Friday at about 150'
The plane has a G26 on it with RCIGN ignition conversion.
Because of the size of the plane, the ignition battery is only inches away from the receiver. It is wrapped in aluminum foil.
The glitching is the same with either a Hitech or Futuba receiver.
I have a Fubuta PCM receiver that could go in the plane, but I would like to solve the problem first. Any suggestions?
Chuck
