RCU Forums - View Single Post - Sealing Control surfaces
Old 01-04-2002 | 08:45 PM
Mode1
My Feedback: (10)
Default Sealing Control surfaces
I seal all flying surfaces with Mono/Ultra/coat. The color of the bottom surface or clear. I use a piece large enough to forma "v" in the gap after extending the control surface in the extreame up position. I allow 1/8 to 1/4 overlap for adhesion. Minimum heat. All edges sealed with water based Poly-u. Lasts the life of the aircraft.
