TOYMAKER
This trick is clean and neat. Use silicone to seal gaps in all surfaces. Make a v-shaped trowel and flex the control surface open. Trowel in just enough silicon to seal and wipe excess that goes thru the gap on the other side. Let control surface go back to neutral and let dry. When needed this type of seal is easy to remove, make sure surface is clean from oil and fuel if your doing this after the fact.
