RCU Forums - View Single Post - First Dumas Prime Time kit
Old 06-19-2005 | 05:02 PM
Robert_K
Default RE: First Dumas Prime Time kit
Hello Chris,
My next model is also the TIME + I allready have the set. But first I must finish my SAR 33 model
which is nearly the same as the original.
Do you have original photos of the TIME ???
Are you building the upper part of your TIME in fiberglass ??
The original TIME has jet-drives using the KaMeWa System ( see photo of crane )
The 28 Kehrer-jet´s fit pefectly to scale. They are also available now with the KaMeWa System.
I build 33 Kehrer-jet´s into my SAR33 whitch I am constructing at present.
They work perfectly / It has worked well.
The Hull at the After-Deck has to be adapted for the jet-drive in the TIME, however.
In the original 2 Citroen 2CV stand / stood beside the Tender.
Ideas
The railing of the original TIME can be illuminated.
I have been send photos of the TIME from a model builder who has build in this function. It looks super.
more Ideas
upper bridge lighting, deck lighting, signal and position lights, headlights, underwater lighting
functioning shower ? functioning jacuzzi ?
Wish you a good "TIME"
Robert
ID:	287101   Click image for larger version
ID:	287102   Click image for larger version
