RE: Tower Hobbies .75 Poor Running
On this engine I believe that you can remove the plug in the carb and the high speed needle will simply screw into it. This converts this plane from a remote needle to a conventional design. Try it this way to see if your remote needle is leaking air. This would cause the engine to lean out in flight.
