RCU Forums - View Single Post - spinner and prop install help!
Old 06-20-2005 | 09:04 AM
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: spinner and prop install help!
ORIGINAL: khoat6
thanks alot bill...
the prop nut (dubro) in the picture was supplied with the engine...
will i need a special prop washer or can i just use any kind of washer? where can i get differnt prop washer and nuts to accomodate my setup....do i have to go to the hobby shop? or can i go to home depot or lowe's or etc...?
The best way is to have the prop washer and the prop nut that came with the engine. Scratch that, I just looked up the engine and it comes with what you already have so everyone knows, here is a pic of it.
I would do the LHS first. It will be more expensive but it will be a better match.
I'm a little short on time or I would do it for you, but a little research may yield someone that has the correct prop nut/washer combo
Here is where I found the picture. It shows the shaft size. Now that I have looked it appears from re-reading your posts that you did do some homework. Cool stuff. I did a very quick look at the recommended lists of items for this engine and it seems you are dead on.
http://www.hobbypeople.net/gallery/211300.asp (there are other places but I'm a little short on time)
I'll be back later to check this out and if no one has posted about finding or not finding a prop nut for you I'll dig a little deeper.
