RE: Evolution 11 trainer
if you look at the weight of the plane it doesn't make any sense....
The Start-40 Evolution II is fully in wood, manufactured by CAD/CAM (computer aid design and computer aid manufacturer) It has a light weight of average 300 grams to 500 grams. This enables you performance training and easy flight. It would need a short runway for take off and landing. The design makes it very attractive in flight position.
Comes with landing gear and its solid design allow soft touch and go landing. This Trainer 40 Airplane allows and supports many bad manoeuvers such as hard landings, small crashes, tight turns, and more! The best way to fly and the easy way to success is the Start-40 Evolution II. Strong and Performance airplane with plywood ribs!
Wingspan: 1450 mm
Length: 1160 mm
Built/Construction: Balsa wood and ply wood
Engine Required: 2C 0.40-0.46cu.in; 4C 0.45-0.61cu.in
Radio Required: 4 Channels, 4 Servos
A 500 gram plane weighs almost 18 ounces and it's calling for a .40 - .61 engine
something doesnt seem right, not to mention why would someone buy something that really doesnt have a history or any reviews done on it
