RCU Forums - View Single Post - Slo-V startup problems
Thread
06-20-2005 | 09:04 PM
4
Epoxy Cup
Jul 2002
229
Salem, OR
RE: Slo-V startup problems
If the crack in your fuse is not to bad there are a couple of fix'es for it[8D]. You can simply run some CA on it and hit it with acceleator. Dont get your finger on it or it will burn[X(]. I find graphite and CA seem very reactive together. If its pretty bad you can wrap some carbon fiber around it or some fiberglass and brush some thinned (with alcohol) epoxy over the repair. And if it's really bad get that replacement fuse.
Good Luck
Reply
Like
Epoxy Cup
View Public Profile
Send a private message to Epoxy Cup
Find More Posts by Epoxy Cup
View iTrader Profile
