Hey Cafusin,
I built a CG Extra several years ago and put the Saito 150 up front. I also used the standard servo tray and ended up adding weights to the tail for CG. If you go with the 150, I would consider adjusting the location of the elevator/rudder servos to the rear of the plane.
Good luck, its a great bird.
