RCU Forums - View Single Post - OS LA .46
Thread: OS LA .46
Old 06-20-2005 | 10:35 PM
AMB
Default RE: OS LA .46
I prop mine the same as Hobbsy for about 9500 max, also as the prop load increases you lower the compression this certainly makes life easier for the engine, by running small props at high rpms and higher compression the advantage of the diesel is diminished. The
exception to this set up of course is the speed control line class martin
