RCU Forums - View Single Post - Could use help with AK Models Cub CG
Old 06-21-2005 | 05:37 AM
Dr1Driver
Default RE: Could use help with AK Models Cub CG
The fuselage should be level at the proper balance point. For a flat bottom airfoil, this means the bottom of the wing will be level. That will be between 25% and 33% of the wing chord. Wallowing can also be an indication of not enuogh power. For a Cub, you also might need coordinated controls in a turn to prevent the tail from dropping.
Dr.1
