ORIGINAL: YNOT
Nope.
Only thing you may want to check is the rudder and nose wheel. Several of them are not set up straight. It is a very easy ajustment.
What do you mean "nope"? The balance on every plane, whether it be an RTF trainer or scratch built war bird, should be checked before the first flight and after any changes which might move the center of gravity. A good example is installing a new engine, unless it's the exact same model.
