RE: nexstar question
Check everything. The Nexstar Select is specifically designed around the OS .46 FXi -- which means that any engine of similar size & weight, when positioned on the mounts in the same location, will give a C-of-G very close to the design spec. However, that doesn't mean that the owner of a Nexstar ARF can safely launch his bird without checking everything in sight.
